I1 Controller USB Any Fix?
Hello, I Purchased a used controller form here that supposed to be working with no problems and of course I get no connection to the go app :mad:, so after researching some info,I took the usb out of my controller put it in the controller I just got and it works now, so it looks like I need a new board,just seeing if there’s a fix.
Thanks for your time and help.
The Editor
Moderator
Staff member
Yes - you've just found it.....replace the HDMI/USB module.
Like asked here.... Repairing/Flashing HDMI Module
There has been no 'fix' other than replacing the module as has been asked many times ....
Just to let you know, You can fix them, It was a long and painful journey"Time spent", but now I know how to fix it, flashing a new BOOT imaged fix it, well I should say fixed two boards
The Editor
Moderator
Staff member
So are you going to post a tutorial to help others? It's a very common issue.
Well, this is how I fixed it. when I was looking for the new part I seen the Inspire1 and the phantom 3 had the same part on the radio, so then I started searching that and found this.
but I couldn't figure out the last part. then I found this video, this guy is awesome and it was easy to follow.
Pius on this GitHub there is a lot of good DJI stuff, have a look on the right side of the page.
New Threads
kccumm
