Moved to correct section as this is Inspire 1 related.For some reason i cant get my inspire 1s legs to come down anymore. it just makes a clicking noise as if its trying ti power the mechanism but nothing actually happens with the legs. anyone know how to fix it?
can you let me know which thread covered this? i searched it before but the problem other folks had appear software related or surface related. mine has worked before and there wasnt a software update and ive tried it on numerous flat surfaces. im just a hobbiest in drones and not very tech savvy so was hoping someone can diagnose for meMoved to correct section as this is Inspire 1 related.
There are so many threads on this already please use search on the forum before posting up a new thread
Search results for query: Will not enter travel mode
inspirepilots.com
Try - Can't enter travel mode on newest firmwarecan you let me know which thread covered this? i searched it before but the problem other folks had appear software related or surface related. mine has worked before and there wasnt a software update and ive tried it on numerous flat surfaces. im just a hobbiest in drones and not very tech savvy so was hoping someone can diagnose for me
Thanks!! i did try the screw method but unfortunately i couldnt tell if the screwdriver ever engaged it - it was a very small hole and the driver can get easily shakem off the groove. I wasnt able to get the landing gear to manually adjust though, but ill try again.
It only needs a tiny nudge - and not while the aircraft is powered on.Thanks!! i did try the screw method but unfortunately i couldnt tell if the screwdriver ever engaged it - it was a very small hole and the driver can get easily shakem off the groove. I wasnt able to get the landing gear to manually adjust though, but ill try again.
