- Joined
- Oct 25, 2017
- Messages
- 57
- Reaction score
- 10
- Age
- 60
No problem thanks for the reply. I'm looking at is there a good reason to spend the extra money for the SSD or just stick with the SD card. I know with SSD you get more information on your video which causes you to have a lot of space being used and lot less footage than someone using a SD card.You know that you can record video to the micro sdcard, 128GB max, in h.264 or h.265 and .jpeg or raw stills.
I did read your initial post, but was not sure you realized this capability, not trying to be a smart alec.
Hi..Firstly have you checked that the I2 is not already licenced? If it is there will be a sticker on the side ( see photo ) and to double check run DJI Assistant 2 .there is the licence section on that programme which will tell you if its enabled or if you have to buy thats where you input the licence numbersIf I want to start using the SSD card on my i2 how much extra do I need to pay in order to start using that feature or just buy the card and the reader and its all set.
FYI- When you buy the ProRes/CineDNG licenses from DJI, you don't get a sticker...just a license code to enter into DJI Assistant 2. Maybe if you buy the licenses with the bird it comes attached, but otherwise the sticker is not a good indicator.
