- Joined
- Nov 4, 2019
- Messages
- 13
- Reaction score
- 3
- Age
- 32
- Location
- San Pedro, Belize
- Website
- www.visualstudiobelize.com
Hi guys, I am new to this and would like some help.
I have been flying my inspire 1 with my Note 9 for a long time and had no problems. The Note 9's screen is not bright at all and I always struggle to see what's on the screen when in direct sunlight.
I bought a Crystalsky ultra 7 inch to use with my Inspire rc to resolve this problem and it did. It provided me with a much brighter screen for viewing in sunlight. But it turns out the crystalsky ultra had an issue when used with the Inspire 1. It would have a very laggy video feed/transmission(running DJI GO 4) that's so laggy it was unsafe for flying.
I then decided to give Litchi a try as I researched and saw people were using it to get normal video feed/transmission while using Crystalsky ultra on the Inspire 1. That also worked out very well. With Litchi installed on the crystalsky ultra, my video feed was back to normal.
One day when I was using my inspire 1 heavily(several flights), on the last flight i flew about 1 mile away and after shooting I started to bring it back home manually(Not RTH). It came back perfectly flying without any signs of weird behavior.
As I was about to land it in the grass, I looked over by our thatched roof canopy and randomly thought how cool it would be to land it under the canopy and onto the cement. So that's what I did, I flew in forward another 20 feet toward the canopy to land under the shade and as soon as it got underneath that shade it shot straight up with full speed, hit the thatched roofing from underneath and crash landed on the cement in upside down position, motors still going at full speed and propellers slowly breaking into pieces. My brother quickly grabbed the drone when he saw an open opportunity(propellers away from hand) and as he held it up firmly I ran towards it and tried to hold power button in battery to shut it off. Keep in mind the drone was not responding to any input as we tried to kill motors via controller input. And as we tried shutting battery of it did not respond either so I finally pulled out the battery just like that with everything still running(had no choice).
Result was, a scraped up body and battery, all propellers broken, and the vibration absorbing board (plate holding the gimbal and camera)was split in two and obviously was not able to hold the camera(X5) and gimbal properly anymore.
I took some time to clean it up, remove the gimbal and camera(X5) and clean that too.
Replaced new propellers and gave the drone a try at flying without camera and it flew great(I was relieved). Tried the gimbal and camera(X5) on my Osmo and that worked perfectly too.
So the only thing I think I will be needing is a new vibration absorbing board and that should get my drone up and running again with camera and all. I Hope.
1 other thing: During this incident the tb48 battery was exactly at 30% or at least this is what Litchi showed after checking the flight logs. And I'm positive Litchi app did NOT give the usual 10 second warning for RTH(Return to home) or I would not have spent those extra seconds trying to land under the canopy knowing what RTH does.
So guys, please be kind and share with me what you think caused this. I was shocked when this happened because it surely has never happened before when using my note 9 with DJI GO 4 app.
So honestly this incident leaves me scared of ever using Litchi ever again. And yes, for now I'm blaming Litchi because this never happened before with my Note 9 or Crystalsky Ultra running DJI GO 4.
What do you think really caused my Inspire 1 to randomly shoot upward and crash when it should have landed instead?
