Inspire 1 crash near to non flying zone
Bulgaria
Hello ,
This is what happened to me in 17 this month.
I shot commercial .
location bordered to the NFZ .
try to take off .Get a warning from DJIGO app for NFZ.
We moved around 3 km from there.
I did check on DJIGO app map .We were outside from NFZ.
compass calibration successful -no warning from DJIGO
compass mod -1539
we shot on the road .
Started motors and take off .inspire raised about 50 cm and go suddenly to the right and hit the road enclosure.
everything happens for two seconds and I had no control of the craft.
no damage .only broken propellers
HealthyDrones.com - Innovative flight data analysis that matters
Thank you for your attention
Hello ,
I shot commercial .
compass mod -1539
Hi Lilian,
Unfortunately your log file is too small (doesn't contain enough data to be of any use).
You appeared to be well clear of the NFZ that surround Sofia airport so I am not sure what happened in this case.
Did you notice how many satellites you were receiving at the time off take off?
The other possibility is that one of your RC sticks was stuck in a position off centre.
This is the problem with using auto take off (which I have never used on either of my Inspires - EVER).
If you use auto assisted take off and a control stick is not rendered then you will get a sudden and violent movement as soon as the aircraft lifts off the ground.
Hi Lilian,
Hi Editor ,
The satellites are 15 .
when Inspire go to the right ,I tried to get it back .
but the right RC stick was not working .sure enough !
I never use auto take off or auto land .NEVER !!!
at the moment I lost control over INSPIRE I saw one red light between the greens,
but no warning from DJIGO .
jammartin
