Inspire 1 Motor's ID Markings
HRO
I bought a used Inspire 1 that has no marking whatsoever on the motors/ shaft/ or adapter, it probably has worn off. I need to know the orientation of the motors, Anyone have a diagram or photo that shows this?
Errr.... Fire up the motors and see which way they rotate?!
Or type in "Inspire 1 motor rotation" into Google.
This comes back
You're welcome
Reactions: Donnie Frank
Here’s a link that has a very good video from our forum here.
Thanks, but Does not help, no audio. No motor ID
You're being obtuse on purpose. The moderator's answer - which includes a video for the love of god - is literally idiot-proof....okay...idiot-resistant, apparently.
Show some initiative and exercise some diligence. Even if the prop mounts are missing (which you haven't stated they are), there are 6 ways from Sunday to extrapolate motor rotation. If the prop mounts ARE there, simply mount the props. The motors will rotate in the direction that provides thrust.
Reactions: The Editor
So starting the motors and idling the four of them (without props attached) doesn't tell you which way they rotate then?
And the motor id M1-M4 is staring you in the face through the entire video as a graphic overlay (apart for the last 9 seconds!).
What more do you actually want?
Sorry,
Had cataract operation and everything was blurred. Better now .GOT IT
kritikabakshi12
