Inspire 1 Pro propeller locks?
I've seen a few threads and read through them, but what I am looking for an answer to is this: I have an Inspire 1 with the "push-twist" propellers. I have seen the Inspire 1 Pro has props that sit on and you twist the lock to hold them in place. Is this a better option? Is there a retrofit kit to use them if they are? I am assuming that they may look better than they perform from reading reviews, and not seeing any install kits...? If this has been covered, please give me the proper terminology as apparently my searches are coming up rather empty. :) haha...thank you!
currently you have the 1345S style props (part 52) which is the "push-twist" those use part 53 for prop installation.
the newer more current style is 1345T (part 69) which use part 70 (older) for prop installation or part 99 (newer)
the two are shown here
Quelles sont les nouveautés de l'Inspire 1 V2
the 1345T are the newer props and are said to be more secure and definite as installed is more noticeable. but then again there is nothing wrong with the 1345S you are currently using
Thanks so much for clearing that up...So I shouldn't bother upgrading at this point then?
personal preff really. me i had the 1345S and didnt really like how they installed, seemed if not done right, or in a hurry they would come off... so i went to the 1345T which i like better but again both function the same at the end of the day.
These are the same as my P4 props so I'll keep them for now and focus on a few other goodies. Thank you! I may get some spares just incase. Feel free to message me on those props you have. Installing the X5 Vibration Absorbing Board today. Got a few batteries and the battery charging hub coming also. Trying to practice my flying daily...
taylahlawson980
