These files have now been removed from the server as the website is being relocated.
wish I saw this earlier, Thanks .There is another way to get your RC updated with a USB pen-drive.
I have placed a RC reset file on one of my websites, this will restore your RC to factory condition.
The instructions are:
1. First download this RC reset patch file by putting it on a pen-drive and update the RC with it.
http://www.weymouth-angling.co.uk/gs_ofdm.bin
2. Then turn off the RC, reconnect the ipad/android and delete the existing DJI Go App, then download it again and re-install it.
3. Restart the RC and then start the newly installed DJI GO App.
4. Click the "Upgrade Required" message and in the next section the App will offer to download the latest FW file and install it, click "download FW file" and when it has downloaded, install it.
For those who still receive an "Upgrade Required" warning.
After restarting the RC you might get the "Upgrade Required" message, if so apply this patch file.
http://www.weymouth-angling.co.uk/C1_FW_V01.02.0021.bin
both patches were tried ,The RC just sat there with a red liight ,no activity that anything was happening
Try this...I cannot get the master Rc to pickup after the latest try firmware up,red light and that's it
Absolutely , so done with them this was my forth quad from DJI - I should have known better . Now my brand 3K I1 sits out in S.CA awaiting its eight week jail term, I live in the N.East ( hell - that's early October ) . This due to a ******** update , that should have never been .So little thought has gone into how to make this work from DJI. It's a second rate customer experience on what I can only say is an overpriced well below standard product.
Well i got the Rc back from DJI ,it would not update,they said the hdmi circuit failed not sure what that has to do with anything.(i use an ipad 2 air with usb)
Now the RC unit will not act as a slave,i just get the pink purple led it shows as slave but does not work , and does not communicate with the inspire 1 so no video.
DJI tech said he would call me back in 2 hrs .well he did not
This last firmware did me in,everything was working fine before the firmware update..I think when things are good stay away from an internet signal ,then you won't know when there is a firmware update.
I really don't know how this is going to end up ,but i am laid up more than i am flying
I have the same issue. The USB port does not connect to anything, flash drive, camera, mobile etc. For this reason it won't update. Its stuck in slave mode and no longer has any link to the I1. The txt file on upgrade from 1.2 to 1.3 said
========== 2014.01.01 00:00:04 remo-con disconnect======
Packet: WM610_FW_V01.03.00.00.bin
Upgrading ...
Result: Corrupted.
Firmware bin file is corrupted, download it again from the DJI offical website.
However now I can't install anything as the USB port no longer works. I can see the slave remote on the masters RC control settings as full signal.
Any ideas if there is another way to upgrade firmware from 1.2 without USB port ?
Welcome to inspirepilots.com! !Try and update your rc to 1.3 and see if the usb port works..
Wait Turbo, you just welcomed yourself to the forum! Not once, but twice, put down that beer!![]()
You can delete your own duplicate posts as I had to do for the same reason. Since the server were recently updated, I have found it slow to respond and at time impossible to connect to (Apple Safari browser). The link times out and the server reported as not responding. At the same time I can view the website on my iPad. Are the administrators aware?Yes ..been having some trouble using the site for the last five days or so..
for whatever reason the site has been running very slowly and things like multiple posts happens and when I try and delete the post it hangs up..sorry about that..
It was perfectly alright before they upgraded to FW1.4!You can delete your own duplicate posts as I had had to do for the same reason. Since the server were recently updated, I have found it slow to respond and at time impossible to connect to (Apple Safari browser). The link times out and the server reported as not responding. At the same time I can view the website on my iPad. Are the administrators aware?
