Inspire 1 V2 TB47 not charging, *attached video of what it does when plugged in
houston tx
My Inspire 1 has been in storage for about two months, and i tried charging both TB47 batteries today and they both do the same light sequence when plugged in, and then nothing after that. also the controller will not find the drone via DJI Go app, but will control the drone to fly it to get off the ground but then it immediately lands with the critical battery flashing red light. Lost as to what to do. I have tried the press twice and press again where all four LEDS blinking, plug it in, and then it still does the same thing. I am using OEM DJI 17.4V 3.3A charger. Open to any suggestions, Thankyou
I’m sorry to inform you but that battery is done. I had the same issues with two of my batteries. E-bay seems the best place to purchase batteries for the Inspire 1. I recently purchased a TB48 for $99. I’ve been using it for the last two weeks and it’s been pretty good. I get about 14 minutes flight time.
Interesting that it's the first LED that blinks. Are you sure your charger is up to par? I honestly expected to see the third LED blink, which is an error code. The first LED blinking is normal for a flat battery. The fact that it stops blinking makes me believe that it may be the charger. Years of flying Inspires and charging batteries (I own about a dozen batteries) and I've never seen the first LED blink and then stop.
me either
My recommendation would be that you go on E-bay and purchase a TB-48. I purchased two recently and they turn out very good. One had only 7 cycles on it and I’m getting 15-16 minutes of flying time with that battery. The other one about 14-15 minutes. I only paid $125 for each. Do your research and make sure that whomever you purchase the battery from, that they offer a return option. Good Luck!!
DawnaTalar
