Inspire 1 V2 Wont connect to DJI GO app searched and tried
So I have flown inspires in the past and was given on as payment for some mechanic work. Has super low use but has been sitting for quite some time. After force charging the batteries with a LIPO charger and getting them to charge and hold charge on the DJI charger, I tried turning on the bird. The bird at first was giving me gimble control and props but NO CONNECTION TO DJI GO APP. I tried several devices and then updated the bird firmware to the latest firmware where i lost props and now only have gimble control. THE RC CONNECTS TO THE BIRD AND IS BOUND, however the DJI GO app does not connect to anything. I tried a multitude of wires, and then tried a brand new in box remote that I had from my old bird. Nothing worked. The usb doesnt even charge the Ipad on lightning cable however it does charge my newer USB C phone go figure.
I then followed Donnie's video on reverting the bird to the old firmware 1.08xxxx and that went smooth. But now I have a bird that binds to the remote no issues but still will not connect to the DJI app. the Problem is I cant update the firmware or even check for connectivity because usually thats done on the app. Apologies for my lack of knowledge. Thanks again!
Remote- GL658B C1 two of them
Bird- Inspire 1 V2
Camera- Base camera with zenmuse x3
DJI GO APP- latest only says how to connect under Inspire 1
Bird- Inspire 1 V2
The DJI GO app is for the Inspire 1. You have to download the DJI GO 4 app for the Inspire 2. Hope this helps.
Bird- Inspire 1 V2
What device are you running the DJI Go app on? I’m using the Mini iPad 6 without any problems. When I use an Android device I’ve found that anything that’s too knew for some reason won’t work. Just throwing some ideas out there. Good luck!
saudiavisa
