Inspire 1V2 parting out
This drone flies again!!!!
Replaced the ncore with a new NCORE, and she's alive!!!!!
San Antonio, TX
Paypal Friends&Family only, shipping is included in all prices to CONUS only.
I believe it's a firmware issue, and if you're smarter than me, you can probably fix it. I've replaced the Ncore, it did not fix the issue. I replaced cables between the camera, still will not finish an update. The log file states that module 305 and module 306 are not found. If you know how to fix that, then you can get this in the air again. If you just want the parts, this Inspire has plenty of them. Message me for questions or if you want multiple items, I will bundle some things if wanted.
$1000
Inspire 1 V2 aircraft, 1 RC and some extra props WITH GPC travel case
3 batteries, no camera, power charger
DJI Inspire 1 X5 Travel Mode Case | GPC, Inc.
$650
X5 camera & 15mm DJI lens
w/ ND filter set - inlcudes circle polarizer and ND8 & ND16
$250
Olympus M.Zuiko Digital 45mm F1.8 Lens (Silver)
https://www.amazon.com/gp/product/B0058PL9QG/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
$200 Remote Control with these antenna and range extenders
Amazon.com: BlueProton DJI Phantom 4 & 3 Advanced/Professional WiFi Signal Range Extender Antenna Kit by ARGtek: Camera & Photo
Amazon.com: WiFi Signal Booster 2.4Ghz 802.11b/g/n Signal Extender WiFi Repeater Broadband Amplifiers Wireless Router 5dBi Antenna: Electronics
$50
Battery mod for adding external batteries - DJI Inspire 1 battery mod kit
$350
SmartPower M100+ battery charger
https://smartpowercharge.com/proddetail.php?prod=SPCM100
$150
Bestam Inspire X5 flight mode case
https://www.amazon.com/Bestem-Aerial-BT-INSPIRE-X5-InsPak-Hard-shell/dp/B01J8CC5V2
This drone currently DOES NOT FLY, but I'm pretty sure it's a firwmare issue.
I didnt expect anyone to buy it complete, but was hopeful. So here is the parts available, I'm hoping someone can use these and I dont have to resort to ebay.
All of this was working until 4th of July weekend when I tried a firmware update on the Aircraft, I believe the camera needs it's firmware updated as well.
San Antonio, TX
$400
Inspire 1 V2 aircraft only w/props WITH GPC travel case
No batteries, no controllers, no power charger, literally just the aircraft and the case
$650
$250
$150 Normal Remote Control with parabolic reflectors
$300
6 batteries
1-TB47 (unreliable, does fly, but triggers emergency landing randomly)
5 TB48 (2 of these seem to be stuck in a firmware snafu as well) so only 3 usable batteries
$50
$350
$150
I am interested in batteries and maybe the modifaction battery clip. With w extra batteries how much extendedlight time believe they say more than 2400 ma
I used 2x 4000mah batteries, and it gave an extra 12-13mins which totalled my flight time out to 23mins. Could only use this once per shoot, as I only had 2 batteries external batteries. THis was normally enough time to get most of my residential jobs done, so it worked out well for me.
If I could do it again, I'd go with 2x 2650 or 3000mah batteries as they weigh less, and that's closer to the capacity in the TB48s. The other option I saw people doing was running a single 5500mah pack, but I didn't have the funds to experiment with different battery setups. I had a working set and I knew my flight times, that wsa good enough.
Sorry for the delay everyone, was off on a 3 day weekend. I'll be responding to PMs shortly.
San Antonio, TX
$400
$650
$250
$300
6 batteries
$50
$350
$150
Is the x5 still available??
San Antonio, TX
$400
$650
$250
$300
6 batteries
$50
$350
$150
Its me again Is! Is the x5 still available by chance?
OliverWright
