If you have three sets out of five doing this then I would say it is how your are treating/using/storing them rather than having three out of five that are faulty!anyone having bad swelling?
i have about 3 sets out of 5 doing this. It seems wrong to just throw these to a recycler and have to pay a massive amount to replace them. is there a fix or a hack someone has worked out as yet?
Can you define more specifically "stored badly".If you have three sets out of five doing this then I would say it is how your are treating/using/storing them rather than having three out of five that are faulty!
Lipos can start to swell is as little as four hours if stored badly.
Orientation is irrelevant since Lipos are sealedthey are stored verticly with the plug section to the top in a ventilated container. they do sometimes sit in heat approx 30+ Celsius .
i should also mention they are a bit over 2 years old .
Hithey are stored verticly with the plug section to the top in a ventilated container. they do sometimes sit in heat approx 30+ Celsius .
unfortunately nothing can be done to fix this condition. The battery has produced gas inside the sealed cell and there is no way to vent the gas out. you will notice that the battery puffs up more in high heat conditions and less in cold conditions. the gas is less dense in the cold.If the batteries have started swelling, is there anything you can do to save them? or should you just trash them and start over?
KirkTHANK YOU so much for that quick reply....I have one last question......
When do I have to replace the batteries? Right now, they are working fine....but I do notice the problem getting worst and worst....Do I have to replace when they stop fitting into the drone and charger? OR.....will they burst into flames and all come crashing down one day? What do you think I should do?
Kirk
Only running that percentage would only be 8-9 minutes of run time??Hi
Based on your information, you have managed to hit all of the handling scenarios that will cause these LiPo batteries to gas. The 2 largest offenders are charging warm and sitting in the heat fully charged (high energy).
If you jobs are time sensitive, you need more batteries to let the used batteries cool off.
a] One of the tricks is to keep a foam cooler (the top cover has 1" holes with sealed ice packs inside. Keep this cooler in the shade and store your batteries in ziplocked sandwich bags (keeping condensation to a minimum)
b] after using you batteries you should put them in a cool place and allow them to completely cool off. You can put them into the foam cooler but not when they are hot, wait until the temps come down.
c] having more batteries and only running them down to about 50-45% will save them in hot weather conditions.
LiPo batteries are a great energy source but require some basic understanding to their limitations in either extreme hot or cool conditions.
Hope this helps
Rich
I just got an Inspire 2 used, and 8-9 minutes of flight is what I have been getting as well. Stinks coming from a Mavic 2 Pro where I can get 15 minutes easy, but still enough to get the shot.Only running that percentage would only be 8-9 minutes of run time??
