- Joined
- Feb 12, 2019
- Messages
- 23
- Reaction score
- 6
- Age
- 48
Hi ,
if anybody can point me to a solution of this mistery I would be very thankful !
problem:
I used Inspire 2 with stock controller for the pilot and Cendence to controll the gimbal. I used Crystalsky on both controllers. I loved how I can adjust the gimbal pitch and yaw speedwith the two sliding switches on the bottom of the cendence.
Unluckily I hard landed my I2 and it had to go back to DJI for repair. Since then I was not able to use the sliding switches of the cendence to adjust the gimbal speed. Also the
the cendence is moving the gimbal and stating it is in Slave mode and I can´t map the gimbal speed to those sliding switched , I can choose flight controller from the menu and map pitch/roll Max speed what clearly is a setting for the Master controller. I think my cendence is mixed up between master and slave controller. I reinstalled the firmware of the i2 with no luck.
work around:
I hooked up an IOS device and to my surprise I was able to change (only) one of those sliding switches to controll gimbal speed. So clearly it has something to do with the crystalsky/ios device but it didn´t help to reinstall the go 4 app on crystalsky.
so what should I do ? everything worked before why shouldn´t it now ?
thanx for your help !
problem:
work around:
