Inspire 2 controller beeping
Oakwood, GA
Just updated my inspire 2 and controller.
Now the controller is beeping and flashing red even though it’s connected to the bird.
Not sure what to do?
Why did you do an update I have never had to do it on mine. I don't use the original controller. I only use the cendence remote control. The only thing I can think of is make sure that your contacted to your wifi and try to do the updates on all the different available updates on it with your wifi and see if that works.
go into the main menu by pressing the icon top right corner screen. Select the the remote icon, then in the menu select calibrate remote. start the calibration and move the sticks all directions to full extension. on the upper left of the remote roll the camera tilt/ pan back and forth. select finish. only takes a minute or so. restart remote. beeping should no longer happen.
pavitrakher1
