Inspire 2 Gimbal/X4S error messages
South East Michigan
So I was able to pick up a damaged I2, I have repaired all of the visible damage and it flies as it should. Whit and without the camera is attached I get two error messages
1. Camera Sensor Error
2. Air Encoder Error (0x400000) check whether gimbal is installed
When I power up the drone the with the X4S camera installed the gimbal seems to "activate" the camera spins around and locks straight forward. The secondary camerahas always worked as it should transmitting images back to the transmitter.
Do these error messages indicate a problem with the vibration absorbing board?
It certainly could be but there could also be other hidden damage. If you wanted to take a chance on the vibration absorbing board being the problem, I have a new unopened one that I would sell to you at a discounted price.
hightouchindustries
