Florida Drone Supply is excited to share with you the new Winglet folding Props that are designed, patented and manufactured by T-Motor.
T-Motor is a long respected name in the propulsion sector of multi rotors; specializing in motors, speed controllers and props.
The newly designed Winglet prop furthers the technology and innovation that allows our drones to fly longer, use less energy and increase the efficiency of the airflow off the tip of the propeller.
Winglet design is used on many aircraft wings - from small private jets to large airliners.
Wing tip vortices refer to the spiraling air the coming off the tip of the propeller. With an ordinary tip, there is a strong vortex created at the tip parallel to to prop. With a downward winglet, the vortex is weakened and moved away from the airfoil (or surface of the prop) allowing for smoother airflow and more efficient lift.
Now, on to cosmetics!
You will immediately see that these props are smooth, glossy and beautiful looking. This is customary of T-Motor; putting great effort into their finishes.
Mounting the Props
Florida Drone Supply worked for months with T-Motor to alter the hub and mounting to allow the Winglet prop to mount directly to the Inspire 2 motor without the use of hubs or 3rd party adapters. This allows for a quick and easy attachment to the motor - and allows your folding props to stay mounted at all times.
Flight Speed and Efficiency
In our testing, we compared fixed props, other folding props and winglet props side by side (and simultaneously with 3 Inspire 2 copters at a time). The hover time seemed to remain the same, but the Winglet props really shined when the copter was in motion. In fact, we achieved speeds in GPS mode up to 30% faster than any of the other props while applying the same throttle. In a head wind, the Winglet props flew at nearly the same speed as a tail wind while the other props moved the Inspire 2 at a substantially slower rate.
You can expect to experience improved flight times if you are continuously keeping your copter in flight.
Price and Availability
These props are available now at www.FloridaDroneSupply.com and can be purchased in a set of 2 (1 pair), a set of 4 (2 pairs) or a set of 6 (3 pairs).
You will find them featured on our home page or with the Inspire 2 accessories.
They are also on an introductory sale for Black Friday Weekend.
Here is a direct link to the props:
T-Motor Folding Props - Winglet Style - Custom for Inspire 2
Check them out!
Thanks,
Michael
Mounting the Props
Check them out!
Thanks,
Michael
