- Joined
- Feb 18, 2017
- Messages
- 51
- Reaction score
- 9
- Age
- 57
Yes, simple adjustment, but realizing, I should never fly with this drone without that Torx screwdriver in case this happens again!!
Better yet, do not let the bird to bounce around inside the case while mountain biking ...Yes, simple adjustment, but realizing, I should never fly with this drone without that Torx screwdriver in case this happens again!!
Oh, any airline than. They'll toss your luggage like a rag doll, no mercy. OK, simple question: will they [airlines] allow you to carry the drone in original box as a personal baggage?Southwest Airlines....
I did bring my p4p on the plane, but the inspire 2 must have been bounced pretty hard in the case. Always bring a torx set with you!!!Oh, any airline than. They'll toss your luggage like a rag doll, no mercy. OK, simple question: will they [airlines] allow you to carry the drone in original box as a personal baggage?
No, my friend. Although having a set of necessary tools handy is a must on any filming expedition, this is NOT the solution! Knowing that such precise instrument will be brutally tossed around by careless luggage carriers, I'll do everything humanly possible to avoid that. If not, something else (hidden) may be damaged, and your bird may go down like a brick, entertaining everybody but you ...I did bring my p4p on the plane, but the inspire 2 must have been bounced pretty hard in the case. Always bring a torx set with you!!!
I watched as they threw the case for my I2 On the belt. It did make me cringe....... the only other option I see is to drive..... - but you are right.No, my friend. Although having a set of necessary tools handy is a must on any filming expedition, this is NOT the solution! Knowing that such precise instrument will be brutally tossed around by careless luggage carriers, I'll do everything humanly possible to avoid that. If not, something else (hidden) may be damaged, and your bird may go down like a brick, entertaining everybody but you ...
