- Joined
- Mar 2, 2016
- Messages
- 59
- Reaction score
- 8
- Age
- 49
Hello
Just thought i would post some pics of a repair i have completed on 2 Inspire 1 V1 arms in case anyone else has a similar issue.
I have bought a damaged Inspire looking to repair it and get it back up in the air.
The guy who i purchased it from had crashed it and sent it back to DJI for repair but once he got the repair estimate he decided it wasn't viable as the cost was astronomical.
So he asked Dji to box it back up and send it back to him , so I have purchased the box containing all the bits .
The main issues are that the 2 arms have a broken tab where it mounts to the arm raising mech
Also the worm drive screw was bent and one of the mounting bolts was missing.
So first I repaired the two arms by using an epoxy called PC7 which is the best epoxy i have ever used , it bonds everying and is also workable when set.
I first had to come up with a way of keeping the mounting hole inline so when everything had set it would line up correctly.
I ended up finding a screwdriver which was the same diameter as the mounting hole so i wrapped some cling film around the screwdriver to aid its removal and applied the PC7 epoxy.
It doesnt look pretty at the moment .
With screwdriver and other bits removed
I now had a solid mounting tab with a correctly aligned mounting hole.All it needed was a tidy up with the Dremel to make it the same profile as the original tabs.
I followed this procedure on both arms.
I then had to set about straightening the worm drive which was achieved with a vice and rubber mallet and a lot of patience.
Then a had to make a mounting bolt which was done by finding a bolt with the same size thread as the original and then using a grinder to remove the thread down to the same number of turns as the original and then moving to the dremel to get the shaft that was left to the correct diameter to fit into the mounting holes.Then i ground down the bolt head and to the same thickness as the original and shave 2 sides of the head so i could get a spanner onto it to install it.
I seem to have misplaced the photos showing the bolt and arms before i reinstalled them but i will try and find them and post them up.
So below is the finished arms installed in the landing gear mech.
I'm actually surprised how stiff the landing gear assembly is , there's no play where the arms mount
I have manually screwed the landing gear up and down using the screw underneath the body and it goes up and down without an issue.
I dont have a controller yet so cant test the landing gear under battery power but a controller is on its way thanks to fleabay.
So once it arrives i will do an update to tell you whether it all works correctly.
Below is my first test fit of all the parts and its looking good.
Hope this helps anyone with the same issue!
PwackInspire
PwackInspire
