- Joined
- May 1, 2015
- Messages
- 59
- Reaction score
- 21
- Age
- 75
Moved to correct section and please use the search function as this has been covered numerous times before.I am getting 6 slow green blinks then two slow and longer duration red blinks. Continuously. IN2 manual says nothing. Cendence is in "P" All batteries are fully charged and switched out. Only thing I can surmise is IMU issues? But Inspire2 was IMU Calibrated last week. Any help?
DEar Moderator; I searched without luck to find other threads/discussions and could not find them. Sorry to bother, but however the "correct" section may be..it wasn't clear to me...whatsoever. Which section was it moved to?????Moved to correct section and please use the search function as this has been covered numerous times before.
You are in an altitude restricted area such as an AIAA or close to a NFZ or other restriction.
Status Light gives repeating 2 long red flashes??
Today for the first I experienced two solid red status light flashes before take off and also during flight. The two long red flashes were followed by several normal green lights. According to the Manual solid red means Critical Error. Red flashing means IMU Error. But this was neither. There...inspirepilots.com
6 green 2 red 6 green 2 red...
Hi, can someone help me and tell what this mean when the lights flashes six normal green, then two a little slower red and then again six normal green and again two reds. This continue for a long time. After shutting the aircraft down and restarting, it did continue like that. No other warnings...inspirepilots.com
2 long red flashes and then multiple short green flashes
Nothing in the dji pdf's about the status light indicator describes a sequence of 2 long red flashes followed by quick green flashes, then repeat. It is a relatively new Inspire 1 pro using full batteries. Multiple batteries produce the same result. Anyone tell me what it means please? Edit...inspirepilots.com
Inspire 2 section (you were asking about the led sequence on your I2).DEar Moderator; I searched without luck to find other threads/discussions and could not find them. Sorry to bother, but however the "correct" section may be..it wasn't clear to me...whatsoever. Which section was it moved to?????
DJI do not document this - they should but they don't.Thank you but the thread answers went all over the map...from IMU issues to what seemed to be the consensus, but no definitive statement as far as I could find, nor any DJI documentation): the INSP2 was approaching a NO FLY zone..or at least DJI's concept of same. Today I few the IN2 exactly in the same location for 45 minutes with the same LED pattern. no flight issues. With FAA signed letter of approval and NYPD Aviation's nod as well, the automatic DJI geo fencing was at work? I'm glad I didnt have to request DJI to release my drone.....given they are closed due to the virus...tho I suspect the "release" process is automated? As I was out in the boonies with no WIFI..but 2 miles from JFK and under 200 feet.
Thank you. I was indeed in a delicate area, with FAA clearance. If I had downloaded the DJI latest geofencing stuff, I probably would have been prevented to fly, necessitating to unlock via the excessively cumbersome unlocking process with DJI restrictions, even tho I had written authorization from the FAA for my team. My multiple flights were totally successful...Inspire2 worked perfectly. I flew under 200 AGL as per our FAA clearance. No problems whatsoever.DJI do not document this - they should but they don't.
The sequence of lights you describe is because your are/flying in or near a restricted zone.
That is the definitive answer.
