What do you guys think?
Also, is this a different Z-axis accessory than the one advertised for the X3 on the DJI Webpage?
HiGot my Z-axis for the X3 today!
I found it better than not having it. I still had to try and compensate for the up/down by 'hand' I had to watch and make sure the arm was not hitting it's end points by tilting the handle slightly. I reckon it will take more practice to hone the technique.Hi
I have received mine today as well. Did a quick run down the garden and back but still getting jerky footage. So I suspect more testing is required. How are you finding your Z axis?
So after waiting 50 days for the X5 adapter and Z-Axis stabilizer, they arrived today. I am dismayed that I cannot make the Z-Axis stabilizer work with the X5 because, as Phil at RC Geeks posted today, the spring is too weak to balance the gimbal and camera. I even removed the lens to see if I could balance it without the lens and the spring is too weak to balance the gimbal and X5 camera even without the lens. I like the idea of the Z-Axis stabilization and I hope someone out there comes up with a spring mod solution. Maybe the guy who made the video… In the meantime don’t buy the Z-Axis for the X5.
So.......let me get this right (I will sit down first and think about it......)Someone reported that if you cut off 1cm of the spring it works perfectly
DJI come up with a z-axis adapter specifically for the X5 camera to fit on the Osmo (different from the X3 Z-axis one).
It is designed, engineered and manufactured solely for the purpose of fitting an X5 camera (and lens) to the Osmo and smoothing out/absorbing the z-axis movement for this combination of equipment.
The only 'slight' problem is...... it doesnt actually work because the spring fitted from manufacture is too weak to support the X5 and Lens (or maybe even the X5 body only)?
However......if you chop 1cm off the spring (and presumably reform the end with pliers) putting it under more tension, then the thing does what it is supposed to do out of the box (but doesn't)?
Is that about right?
Surely, in any country this constitutes a product not fit for purpose and should never been allowed to make it to market?
Absolutely staggering how DJI can keep doing things like this time and time again.That's about right
It works great with the X3 without modification. I may need to chop off 1.5cm for the X5R![]()
A small defect can be excused (occasionally) but something as basic as this has no excuse.
Somebody had to look at this thing and say "Yup, that seems fine, I will sign that off for manufacture"
Do they only employ chimps in the engineering department?![]()
I bet it isn't! The chimps clearly needed more nuts that day.Yeah, all they probably had to do was enable the spring tensioner knob to progress further to accommodate the X5/R, but hey what do I know...I'm a software guy. Maybe it's more complicated than that.
That's about right
