Lens disconnected error and no lens attached reads as M.Zukio Fisheye?
Hi all, my X5s haa the DJI 15mm F1/7 ASPH, it would throw the lens disconnected during flight resulting in no AF control. I gave the gimbal a bit of a shake at the mount and same thing happened, today there is a permanent "lens disconnected" every time I exit and enter the DJI go 4, even if the lens is off the gimbal detects a M. Zukio Fisheye connected.
I have cleaned the contacts, software refresh via dji assistant and everything....
Is it the cable connecting the gimbal mount to the drone itself, the vibration damping board itself or did a wire break sown where in the X5s?
I also read son the forum that the long flex cable can be the culprit...
Small update, after trying the unlock lock ring on trh gimbal she detected the correct lenses and the AF worked... Until the AF/MF switch is flipped, instant lens disconnected (constantly showing up on screen) and when switching back to AF, a pop up says the lens in in Manual Mode.
I also noticed even gently tapping around the lens also results in thr lens disconnected message..... I will have a look again at the soldered pins on the lens itself internally as maybe there is one that has come loose or something.
napkinmath930
