I have deleted your other identical post - please do not double post, it is against our rulesAnybody have the Dec 2016 (1.10.1.4.0) FW update for Inspire 1 Pro? I need to downgrade. Help!
Sorry about that. I’m a little desperate I guess.I have deleted your other identical post - please do not double post, it against our rules
Thank You
I tried doing that. For some reason the log file was coming up as a .exe file.Doesn't sound good. Can you post the logs from the hidden files on the SD card?
Stick card in PC and make sure you have "Show hidden files" turned on.
Navigate to: MISC\LOG and there will be a file called WM610_FW_RESULT_AB.txt or WM610_FC550_FW_RESULT_AB.txt
Post it here. It sounds like you've got the same issue that I had with my X5.
Hey sorry for not replying! I will probably send back to DJI for repair. I tried all the "Fixes" and none worked. I appreciate the help.Yeah, I think you're going to have to send it in for repair at DJI.
Yours isn't exactly the same as mine (I had no device detected at 0800 as well) but the 1500 error is the same.
Can you tell me? Did you have the transmitter switched on while you were upgrading the aircraft? This seems to be the cause of these failures with the Inspire Pros from doing a fair bit of reading and collating of information around the web.
2 things to try though. Clean the contacts on the gimbal and aircraft where they connect together and check the ribbon wires are plugged in securely.
DJI repaired mine for free even though it was well out of warranty. You may be lucky.
