What would the the cause & fix for video recording that looks nervous? It's not judder.
Sample?What would the the cause & fix for video recording that looks nervous? It's not judder.
Yes let us see a sample nervous video please. Else try valium or something similarWhat would the the cause & fix for video recording that looks nervous? It's not judder.
Thanks for asking. Added link to original post.Yes let us see a sample nervous video please. Else try valium or something similar
It seems like a shake or vibration issueThanks for asking. Added link to original post.
Hmmm. Thanks. Wasn't sure if it was vibration or EMI. I do have a new set of props on order, so we'll see their effect.It seems like a shake or vibration issue
This is unfortunatelly pretty typical for I2, amplified by longer lens. Is this Oly25mm?What would the the cause & fix for video recording that looks nervous? It's not judder.
Thanks. I've not had this problem before with the Inspire 2 since putting it into service in 2018. I may need to test different props. Also don't know if a F/W update precipitated it. Updated to: Aircraft = 4.3.46; RC = 01.02.0600; RAW Module to 01.41.01.72; X5S Camera = 01.11.22.29. Calibrated IMU, compass, and 45 mm lens after update and before test flights.This is unfortunatelly pretty typical for I2, amplified with longer lens. Is this Oly25mm?
Generally I2 is not as rock solid in P mode, as the smaller platforms from DJI. You need to learn how to be "smart" with I2 when taking these types of footage and make sure that you always come home with enough of "good usable" stuff which will then allow you to exclude these "nervous bits" from the final cut. Also try to fly in Attitude flight mode. These wobbly moves will be less pronounced in Attitude mode mode than they are in P mode. Gentle drift in one direction is always more acceptable in video (maken them to be a feature rather than a distraction) than these wobbly moves which look to me like result of corrections applied by IMU in P mode. That is the only piece of advice I can offer.
Well, I've had my I2 for almost 6 years and it has always flown more or less like this. Do not thing that any FW has made historically any difference to this behaviour. Perhaps you have not noticed in the past or used wider lens when this wobble was not so noticeable? I guess you'd have learn how to live with this. Not much else I can offer, sorry.Thanks. I've not had this problem before with the Inspire 2 since putting it into service in 2018. I may need to test different props. Also don't know if a F/W update precipitated it. Updated to: Aircraft = 4.3.46; RC = 01.02.0600; RAW Module to 01.41.01.72; X5S Camera = 01.11.22.29. Calibrated IMU, compass, and 45 mm lens after update
