New Firmware v1.9.1.30 - 7/7/16 Help updating
hi all
im trying to update for 7/7 firmware release
nothing happens
tried few different cards
did all by the book
this is not my first firmware upgraded and now the drone is not updating
did someone have the same issue?
hi all
nothing happens
did all by the book
I have changed your thread title to something a little more descriptive than "new firmware"
hi all
nothing happens
did all by the book
What do you mean "nothing happens"? Are you sure the BIN file is for your bird? I did mine just minutes ago, went quickly and smoothly ...
Hi all
Just quick update
DJI help me solve the problem downgrade to 1.8 and then upgrade to the latest version
I would like to have some help understanding the FW process on Inspire 1. It seems it was successful but I still would like to better understand the process. First of all the following is the results from WM610_FW_LOG_AB.txt
========== 2014.01.01 00:00:04 remo-con disconnect======
Packet: WM610_FW_V01.06.00.40_Fcam.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:06 remo-con disconnect======
Packet: WM610_FW_V01.09.01.10.bin
Upgrading ...
Upgrading ...
Result: Success.
========== 2016.07.08 09:26:36 =====================
Packet: WM610_FW_V01.09.01.30.bin
Upgrading ...
Result: Success.
This was on a freshly formatted SD card which has never been used with the inspire before. What I find confusing it seems to show that in 2014 the camera? was upgraded to 01.06.00.40 and the aircraft was updated to 1.09.10.10, which did not finish and then again to 01.09.01.10 which did complete. This is a new T601 less than a month old so the 2014.01.01 is confusing. Also I do not understand where this is coming from since this was virgin SD card.
Also I do not get any of the sounds or lights I expected to hear and see. All I get is a yellow flashing light. When I first got the Inspire I thought the FW update was not working and did not wait 25 minutes. Is this normal to not get any indication that it is updating or that it is done?
After the update I have:
App 2.8.4
Aircraft 1.9.1.30
RC 1.6.0
Camera 1.8.1.00
No mention of the battery. And that brings me to the last question. Do I have to do this 25 minute update for each and every battery I own? I am about to buy a new battery, will I need to update the battery when it comes in?
I will post another message with the hidden files and the errors messages it contains.
While 1.9.1.30 does seem to be successful there are lots of error messages in other files, BTW I do have an OSMO handle and use the X3 on both the Inspire and the handle. I added the color and emphasis to help understand the files. Red indicates what I would consider unusual for an update.
The OSMO_FW_PROGRESS file contains:
Last login: Fri Jul 8 10:22:24 on ttys000
Daves-iMac:~ davearmbrust$ /Volumes/Inspire\ FW/MISC/LOG/OSMO_FW_PROGRESS ; exit;
-bash: /Volumes/Inspire FW/MISC/LOG/OSMO_FW_PROGRESS:
cannot execute binary file
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
from OSMO_CAM_VERSION
Last login: Fri Jul 8 10:27:06 on ttys000
Daves-iMac:~ davearmbrust$ /Volumes/Inspire\ FW/MISC/LOG/OSMO_CAM_VERSION ; exit;
/Volumes/Inspire FW/MISC/LOG/OSMO_CAM_VERSION: line 1: ?A??:
command not found
logout
Saving session...
...completed.
[Process completed]
Next I will post the WM610_FW_LOG_AB.txt file.
The 1.9.1.30 from 1.9.1.10 upgrade data from WM610_FW_LOG_AB.txt part 1.
[00007509]========== 2016.07.08 09:26:36. boot(15) ============
[00007564]Packet
[C:\WM610_FW_V01.09.01.30.bin] detected, card sn [0x70c158b0].
[00007615]Packet upgrade start...
[00007677]Packet checking...
[00007755]Packet vlink 01.09.0130 <-> 01.08.0100.
[00007804]Record vlink 01.09.0110 <-> 01.08.0100 (flow = 0).
[00007851]Done.
[00007907]Version checking[1]...
[00007971][08 00][00] v2.14.9.42 -> v2.14.9.42
[00008019][01 00][00] v2.65.5033 -> v2.65.5033
[00008093][01 01][00] v2.65.5033 -> v2.65.5033
[00008271][03 05][00] v34.1.0.5 -> v34.1.0.5
[00008366][03 06][00] v2.4.20.18 -> v2.4.20.18
[00008432][04 00][00] v1.29.0.92 -> v1.29.0.92
[00008570][05 00][00] v3.0.6.2 -> v3.0.6.2
[00008681][09 00][00] v3.0.0.4 -> v3.0.0.4
[00008786][11 00][00] v3.9.0.0 -> v3.9.0.0
[00008886][12 00][00] v1.11.0.0 -> v1.11.0.0
[00008985][12 01][00] v1.11.0.0 -> v1.11.0.0
[00009086][12 02][00] v1.11.0.0 -> v1.11.0.0
[00009186][12 03][00] v1.11.0.0 -> v1.11.0.0
[00009354][15 00][00] v1.1.2.0 -> v1.1.2.0
[00009448][17 00][00] v1.1.0.6 -> v1.1.0.8
need upgrade.
[00009587][17 01][00] v2.0.1.6 -> v2.0.1.6
[00009650][19 00][00] v1.0.8.96 -> v1.0.8.96
[00009696]Done.
[00011774]
Waiting for user confirm...
[00021850]
Timeout, start upgrade automatically.
[00021945]Firmware upgrading[1]...
[00022006][17 00] Firmware upgrade start...
[00063798][17 00] Firmware upgrade finished successfully.
[00063845]Done.
[00063893]Version checking[2]...
[00063954][08 00][00] v2.14.9.42 -> v2.14.9.42
[00064003][01 00][00] v2.65.5033 -> v2.65.5033
[00064054][01 01][00] v2.65.5033 -> v2.65.5033
[00064140][03 05][00] v34.1.0.5 -> v34.1.0.5
[00064220][03 06][00] v2.4.20.18 -> v2.4.20.18
[00064294][04 00][00] v1.29.0.92 -> v1.29.0.92
[00064380][05 00][00] v3.0.6.2 -> v3.0.6.2
[00064440][09 00][00] v3.0.0.4 -> v3.0.0.4
[00064540][11 00][00] v3.9.0.0 -> v3.9.0.0
[00064640][12 00][00] v1.11.0.0 -> v1.11.0.0
[00064740][12 01][00] v1.11.0.0 -> v1.11.0.0
[00064840][12 02][00] v1.11.0.0 -> v1.11.0.0
[00064981][12 03][00] v1.11.0.0 -> v1.11.0.0
[00065894][15 00][00] v1.1.2.0 -> v1.1.2.0
[00065961][17 00][05] v1.1.0.8 -> v1.1.0.8
[00066081][17 01][00] v2.0.1.6 -> v2.0.1.6
[00066150][19 00][00] v1.0.8.96 -> v1.0.8.96
The battery shouldn't take 25 minutes to update.. I should take more like <5 mins.
GroverBaez
