Nuisance, bug or operator error
Phoenix, Arizona
I have the Inspire 1 X5R.
I made sure to display the right page on the DJI site to get the latest firmware 01.10.01.40
I did the upgrade and everything seems to be fine after a couple of flight.
However, I get the warning that I need to update the camera when powering up.
Also how to make sure the batteries are updated?
Thanks for any help.
I've also got the x5r, did exactly the same as you and have that error. Updated the firmware by following the correct procedure, same as always. Inspire and camera both working well, but it's alarming to see that error notice. Posted on the main DJI forum, but no response, so potentially something missed on their side?
I'm having the same issue.
I noticed in the about page that my aircraft says v01.10.01.40 but the camera says v01.10.1.40 I don't know if that missing zero means anything but I thought it was strange given the issue.
I have also noticed that it will say the status is normal if I turn on the controller after turning on the aircraft with the micro sd that has the .bin file for upgrading on it inserted. But if I power down and remove the micro sd when I power back up I get the camera firmware warning again.
Haven't noticed any performance issue but it is certainly unnerving.
If anyone tracks down any info let me know. Thanks!
DarleneSey
