Odd Firmware experience - ESC Firmware miracle
DJI GO shows me I have installed 1.04 in the plane and 1.03 in th RC.
Previousely I had installed 1.05 in the Aircraft but because of the insane alt limit did a rollback as advertised to work. I has worked - with some parts at least like the alt limit can be waived again.
Now the following is odd:
My ESCs (m1200-m1203) have all installed FW 01.11.00.00 - looks fine if there would not be one problem: all Firmware under 1.05 has ESC Firmware highest 01.08.00.00, in fact only 1.05 has 01.11.....
So there are only two explainations which until now I didnt find out which one is true:
1. The Firmware rollback didnt work - or at least not for the ESC Firmware
2. DJI secretly and without my agreement installed parts of FW 1.05.0034 over my RC.
You can check your ESC Firmware version in the PC Flight Simulator Logs. If you never installed anything higher then 1.04.00.10 and find ESC 01.11.00.00 there you probably should be concerned.
If someone could look into his Inspire feedback any help so solve this miracle would be welcome.
Reactions: AcesAreWld
So why I'm not surprised?
I will not update my Inspire anymore because of those hidden limits.I'm fine now.There where more then enough people talking about you will not be able to downgrade in the next future and as far as I know DJI they will not tell a **** thing about this.
ESC version 01.11.00.00 is also included in the Inspire Pro firmware, also Maincontroller, and m0800 - anyone knows what this is? - are changed in the Inspire Pro firmware though on the screen it will show as 1.04.00.10. (i am not speaking of gimbal m0400 and camera m0101 changed because this is obvious I am only speaking of the "additional" changes)
Rollbacks are partial. For example upgrading from 1.03 to 1.04 updated like 13 components, while a downgrade from 1.04 to 1.03 only changed 2.
Seems downgrades only apply to the "main logic" aka behavior, but all other components stay on whatever version they are.
prammanadi
