One device for dual operation
The Bay
www.rogerapolinar.com
I have two transmitters and only one device to run the DJI Pilot app. When working the dual operator mode the slave has to send a request to the master through the app to take gimbal control. I had to install the pilot app on my girlfriend's device, connect that to one of the transmitters, then finally able to make it work. Do I have need two devices every time?
Do you have an external monitor you can hook up through HDMI? If so, I would just have your camera op on the slave controls using the HDMI output to view the camera, and you be on the master with the slate device that is hooked up and talking to the I1 for communication during flying...
Reactions: SkySav
You won't need to press that again until you use a 3rd controller and request control from that one.
Reactions: SkySav
Kik rah was right! Only have to have the slave request permission once and now every time the slave is out it can control the gimbal. Thanks for your replies, all.
globaldegrees
