I am aware that they should be in rabbit ears position but I often find the stick touching the CS on Cendence and sort of hiden behind, as I like to have the CS quite flat on the controller for best viewing. For the sticks to be more "exposed" is it a good idea to swing them downwards pointing to the ground instead of up? I know how is the RF signal dispersed from the sticks and that the weakest signal is directly above the points of the stick. So for best reception the flat parts of the sticks should be facing the drone. For example if the drone is directly overhead the sticks should be parallel with the ground etc. Any thoughts from radio experts on this?
