Question for everyone
usually T600 is V1. but DJI was lazy when they switched to V2 and used up old stock so the early V2 came marked like V1. if they have the larger X5 mounting board, and the motors are marked 3510H then its more than likely an early V2.
if you want post the serial numbers found under the tail light and i can tell you the build dates of each
Gotcha.... it’s got the same motors the inspire 2 has, plus leg extensions, and the upgraded gimbal mount, so it threw me off. I believe it has hacked firmware. Ridiculously fast
Reactions: thinglenn40
StyledReverie
