- Joined
- Apr 27, 2015
- Messages
- 4
- Reaction score
- 2
- Age
- 62
. . and by "removed" I mean the gimbal mount (and gimbal bracket for that matter) is for the moment not in the bird.
Backstory: New pilot, planing to use the Inspire as a professional tool, amazed by the machine, flight characteristics etc., simply blown away and marveling that the systems work so well, . . 20 or so successful flights and then, I did something I promised myself I wouldn't do. I was showing off/hotdogging in front of some friends and clipped a twig on a low branch (just a bit) dropped about 10 feet with landing gear up, so the camera took the hit. The camera/gimbal is toast (deservedly so, doh!) but the rest of the craft is (seems) fine, I can't find a scratch or mark on her, the props didn't even get damaged. My replacement camera/gimbal arrives in 2 days and the gimbal mount is for the moment removed while I repair a crack gimbal bracket. In the mean time, the Bird *flys just fine, smooth, no funky noises, wobbles or otherwise so I feel pretty lucky.
*The only fly in the ointment is that although I get the expected "Not Connected" warning in the center top of the app (the camera sure isn't connected, it's in pieces!) . . AND I also show the GPS bars locking and then getting a strong connection, AND the app shows P-GPS mode, . . BUT in fact it's not flying with GPS. Post crash the Home point does not automatically set and canot be set manually. RTH just brings it straight down and the flight characteristics don't have the braking effect and it will drift from a hover in light wind, . . no GPS, Hummmmmm . .
THE ISSUE: With No Camera, Gimbal Mount, Gimbal bracket attached to the bird AND the 2 ribbon connectors from the body that go to the camera ara also removed for the moment, . . the Bird flys fine, shows good bars and says it's in P-GPS mode but in fact is flying without GPS.
I have checked the other ribbon connectors on the bird as I went though every inch looking for any damage but everything is tight and looks fine.
HERE IS MY QUESTION - Any experienced pilots/operators/app-software-geek-gods have any insight or ideas about this funky GPS behavior without the camera attached? Could the lack of ribbon connectors that would go to an un-mounted Gimbal receiver be part of this behavior?
Obviously I am hoping that when everything is back together I will regain actual P-GPS flight and have not damaged the GPS hardware. I'm crossing my fingers that this totally boneheaded bad pilot move will only cost me the $550 for the replacement camera and I can avoid sending it to the black hole of DJI repair. I will update the post/thread if anything changes once I get the new camera and assembly back together and the bird in the air . .
. . but in the mean time, any thoughts, ideas or insight would be greatly appreciated - Thanks Guys!
Doc Paradox
Doc Paradox
