smh... Stripped a nut on motor
Ottawa,Canada
Ok i was about to upgrade my backup inspire with the 1345T's and i forgot about the lock tite i added as extra safety... So now i have 1 stripped screw any tip on how i can get this thing out? I tried a bigger size allen key and still wont budge. And no i am not drilling in the motor...
Which loctite did you use?
Only a drop of loctite per screw. Less is more. Vacuum and use compressed air on your motors as well. You don't want blue loctite debris in there.
Reactions: Predator
Thx man but might be too late... I only used a drop but might be a tiny bit ill see with a flashlight. Or what else can i do just let it hover and see if it burns off?
The best thing you can do (if the surrounding area allows it) is to heat up the screw with a soldering iron and let it cool down. Always worked for me very well.
Had the same problem on the weekend with 8 motors from my Okto, all motors had a way too much loctite :-(
Reactions: Predator
AdolphJuq
