With all the changes lately happened there are many open questions. Lets see if we can find out more.
Specs changes: With all Inspire 1 versions specs changed from
range up tp 2km without FCC / CE diversification to
range up to 5km FCC / 3,5km CE
Inspire hardware version changes:
With these specs changes came a version change from WM6101410 to WM6101510 which has ~5 more dBm power. The specs indicate that this new hardware change applies to all Inspire versions.
RC hardware version changes:
GL658B was changed to 658C which has ~4 dBm more power.
Now the questions left:
1. How is FCC / CE triggered?
- why this diversification did not exist before?
- is it the new RC firmware doing this?
- is it determined by tablet location settings (like channel selectin is)?
- will there be a move from tablet settings indication to automated firmware/GPS indication?
2. How this specs - which have been changed on DJI site already for all Inspires - should work for the hundreds or thousands? 1410 / 658B Inspires or the 1410 / 658C first batch Pros which are on stock in all the stores worldwide?
3. I assume the range cannot be the same for a 1410 / 658C and a 1510 / 658C or do the 5 dBm more on the plane have no influence on the range at all? Is it ONLY the RC dBm doing the range?
