- Joined
- Feb 8, 2015
- Messages
- 202
- Reaction score
- 124
- Age
- 46
- Location
- Sussex, England
- Website
- www.visualair.co.uk
OK this is the first time something like this has happened, basically did a couple of flights tonight, everything perfect as normal, landed the TB48 at 31% and TB47 at 28%, both battery voltages equal in all cells.
Come back home later to charge up the batteries, and always out of habbit check the power on the battery and both batteries showed led 1 lit with second flashing, as soon as I put the TB48 into the charger and switched on to charge, it started flashing just the led1, and continued to do this for quite a while. Seemed a little strange, so I swapped to the TB47 and a quick check before, led 1 lit and second flashing, as soon as its switched on with the charger, exactly the same as the TB48, flashing led1, so I immediately thought I would check this within the inspire, and its showing 2% critical battery with all cell voltages at 3.77 then dropped to 1%. Even shows the 1 flashing LED on the battery power check too.
This is very wierd and obviously triggered from the charger somehow. How could the charger suddenly cause them to read a loss of 26% battery power? If this happened with just hte one battery then I would have questioned the battery itself, but to happen to both batteries definately seems to point towards the charger.
Anyone ever had this before. I just have the standard charger, latest firmware installed, have already flown without any issues with the latest update as well. Totaly baffled to why this happened.
Any thoughts would be great
Thank you
Sam
Thank you
Sam
