Strange glitching in video and some stills????
Houma, LA
www.kvphoto.com
I'm getting some strange glitching/noise in my images and video. As I fly if I get a gust of wind, or if I stop suddenly or change directions, I get the "noise" you see in the attached images. What do you think this is? Do you think I need to send my drone in for repair???
LET ME KNOW...and Thank you!
Kirk Voclain
Kirk Voclain
I would try cleaning the contacts on the gimbal and the antivibration plate first. Then check that the yaw motor and bayonet attachement are not wobbly/loose screws under the cover plate on the gimbal site. Then clean also the contacts on your microSD card and the slot where it goes to. I use contact cleaning spray and cotton tips for this. You may also apply a tiny amount of gold DeOxit to those strip gimbal connector contacts. See if this helps. If not change the microSD card. Only as a last resort send it in...
Kirk Voclain
Search function is always a good start?.....
I looked at everyone of those threads and none of them are the patterns that I have!!!
Two of those threads show exactly the issue you have together with some suggestions regarding contact cleaning and reseating the camera.
SanCap has confirmed that it is mount related.
You will need to replace this.....
Fitting instructions can be found on YouTube etc
THANKS....that was most helpful! the part has been ordered...and YouTube has been watched.....
Kirk
Kirk
I actually have a new one in package that I no longer need and would have sold you at half the price but I didn't want to take advantage of the situation. Be very careful doing this yourself, some of the wires are very fragile.
pavitrakher1
