TB48 Are Here
Rig
Just arrived, residential delivery. TB48 are finally trickling into the continental US.
Ordered from Coptershop.
One on the right looks discolored and puffy.... send it back.....oh wait... it's only the box!:D
Rig
Just to note-
To "update" the batteries I did the aircraft update via the SD card method, as per DJI's suggestion, but there is no beeping from the bird, "da-dada" confirmation, or visual prompt in the app. Either the battery update process doesn't behave the same way as the aircraft update process, or these batteries came with FW .16 installed from the factory.
Big Bear, CA.
Just to note-
You can verify this by checking the Log in the MISC/LOG/ hidden dir on the card.
(you must enable hidden dir access in your OS)
Rig
Thanks Blade. Hidden TXT file displays:
result: cancel
Also, the app does not prompt to update the battery, as the instructions say it would:
I'm assuming it's detecting the aircraft FW and canceling the install process, which is writing the hidden txt file. Battery FW must be up to date if I'm not getting the prompt.
Big Bear, CA.
result: cancel
Correct, all up to date.
Have been in contact with DJI about upgrading Batteries,but they told me it's not necessary.Hope this is right
sanaodling
