TB48 Battery percentage
Hi All
Hoping you may be able to help on this, i have 3x TB48 Batteries and have conducted a series of tests to check the % my inspire takes out of the battery life every minute. My results are below. I would like to know if this is what others appear to be getting out of there batteries. it looks as if its drawing approx 5% every minute which i believe is right but are others experiencing better flight times. Inspire flown at 30 metres with constant stick input.
TB48 – Serial: 116 , Discharged to 10% , Charged on Multi-Charger
Before Take-off 100%
30s – 97%
1 min – 93%
2 min – 88%
4 min – 79%
5 min – 74%
7 min – 64%
9 min – 54%
10 min – 49%
12 min – 39%
13 min – 34%
14 min – 29%
15 min – 24%
16 min – 19%
17 min – 14%
18 min – 9% Aircraft Landed
Hi Scott Thanks for that i figured these were normal. At around 30% i came down to 1 metre off the ground at this point i wouldnt risk flying at a greater height on lower power Liam
Reactions: Scotflieger
Looks fairly typical, a few things can give you the ID extra minute or two depending on your ASL altitude and the air temperature. Also the temperature of your battery when you started.
annettekirtont
