You mean their command case?Does anyone have a titan antenna system for your I1?
Haven’t used either one. There’s a member on here that uses their command case and is real impressed with it. I use an itelite on my controller and it works quite well on stock power. Can go up and over a hill a little ways and still carry a good signal. Getting in behind trees kills it pretty quick tho unless at a closer range. Was thinking of also doing an amped setup but just might wait till they get the whole 4g network connection down pat and go that route.Like their atlas and conquer antenna
What's Ur thoughts on increased range? Overall opinion of the panel?I have the atlas on my inspire 1 controller.
very heavy. good thing about it compared to the cyclone is that the whip antennas are removable so you can just fly them with just the whip antennas and not use the boosted panel.
I just finished 5 flights with the Atlas. I took it out to 2800 ft away with perfect reception. I know that is not a big deal but you also need to know the conditions. New Jersey pine barrens with super dense trees on average 50 to 60ft tall. I was rarely able to do a lower flight, say 120ft high without losing signal at about 1500ft away. So to achieve 2800 under the same conditions and hold full bars made me very happy with the performance. The other thing I noticed was my Ipad mini 4 was not lagging or getting green screen. hope this was a fix and not just a coincidence as I did not really want to invest in a crystalskyDoes anyone have a titan antenna system for your I1?
