Travel Mode and Rear Tail Light not working
I1v2 will not enter Travel Mode. Tried both the RC switch and the app. Used to work. Gear works fine otherwise. In fact I just replaced the central frame jack screw mechanism after a gear up landing stripped it out. The rear tail light quit working as well. I point this out because the light and the vision positioning module both plug into the same circuit board. Any ideas? If I need to replace the circuit board...what am I looking for (part name/number)?
Thanks.
Stephen
Is it possible the downward sensor is dirty? What are you putting underneath it to excite the sensor?
Hey Donnie
I actually bought a replacement and it came with a new cable so I am thinking it the the board.
If you recall, you were helping me with a drone linking issue and version management. Suddenly the website kicked me out as a spammer. The thread with you was the only posts I had created. One cannot contact the admin even though it tells you to do so if you felt it was a mistake. Anyway, I had to use another email address and create a new account. Geesh!
Reactions: Donnie Frank
hpstudyguide
