- Joined
- Mar 16, 2016
- Messages
- 121
- Reaction score
- 53
- Location
- New Castle, NH
- Website
- cleareyephoto.com
After flying, I am having great difficulty removing the white CCW 1345T props. I can easily remove the red CW ones with only moderate hand pressure required to turn the locking mechanism. But turning that mechanism by hand to release the white ones after a flight is just about impossible . The front white one is worse than the back one.
I can turn the mechanism and remove the white props using channel locks, but I'm not happy about using them on plastic parts, and I'm concerned that I'll damage something, or even weaken the whole mounting hub due to the extra force I need to apply.
Anyone else having this problem? Any suggestions?
A bit more background: My Inspire 1 is fairly new, and came with the latest 1345T props and mounts, so it's not a retrofit kit installation issue. I have checked to make sure the white props are properly seated before locking them in place, and made sure there's no dirt or grit that would contribute to the binding.
Thanks in advance for any insight you can provide. And, as a new member on this forum (first time poster here), let me add that I am so grateful for all of the fantastic info I've found here. Thank you all for being so helpful!
