- Joined
- Oct 12, 2016
- Messages
- 1,090
- Reaction score
- 567
DJI have just made an announcement about new versions of DJI Go and firmware and needing to re-login/activate. Applies to all aircraft except standalone A3/N3)
If you update and don't re-login/activate with the new firmware/App then you'll have a restricted flight area around take off point as the aircraft won't know if it's in an unrestricted/non-geogfenced flying area or not. If you activate again, then you can carry on flying as you did before within the limits defined by the local flysafe restrictions/no-fly zones.
I'd guess that if you don't update either firmware or App, then nothing much will change from what you've got right now ....
See their announcements (they're both different links) ->
DJI Updates Process For Activating Software And Firmware Updates
I'd hazard a guess that they're acting to place a default safety restriction of 50m/164ft radius and 30m/98ft height if the aircraft can't determine it's location to be free of any geo-fencing restrictions. That will probably stop the tin-foil over the gps trick
