Uncertainty on Correct Panasonic 14mm-42mm Lens to Order.
I need a great all purpose lens for an upcoming project and see the Panasonic 14-42 as a good choice. I'm confused which one to order. I see a full sized Panasonic 14mm-42mm and a compact 14mm-42mm. I know I'll order the wrong so which one is right?
If you have another recomendation on which lens I should order please let me know.
The compact (pancake) lens is the correct one. I’m not sure the other model will balance correctly.
Reactions: Phil DeVore
As stated just ahead, the compact is correct one. Photography supplier incorrectly said and sent the full-sized. Not only would the full size not balance correctly, but the camera and/or software didn't recognize it (i.e, it wouldn't zoom and didn't provide the onscreen remote zooming feature). Supplier switched for the compact. I couldn't find a black compact one (maybe they don't make it?), so I settled for the silver one. I am not an expert in this and I'm only relating my experience with this lens. Hope that helps.
EarthmovingAdelaide
