Up=Dating Firmware
Everytime I up-date the firmware on my I2 do I have to do it once or do I have to do it with every battery pair I have?
Depends on the firmware update. If one set needs it when you are done with update then all will need it. The update notes posted will tell you if it contains a battery update. It does not take long.
It depends on the type of update. With these batteries being "intelligent", if the update is associated with the batteries, then each battery (set) will need to be updated with the firmware. If the update is just for the drone, you won't need to change out the battery (sets) to get everything updated.
AdolphJuq
