USB debugging is disabled. Please enable it first
  • Thread starter Thread starter Deleted member 20043
  • Start date Start date
Guest
I brought this problem up before and I thought I solved it, but I didn't. The problem came back.
Evert time I start the DJI pilot app and choose Camera, I get the message USB debugging is disabled. Please enable it first.
To solve it, I finally reset my brand new Nexus 9 (approved by DJI) tot Factory settings, removing all apps and data from my device. Then I reinstalled the DJI pilot app.
It didn't solve the problem. I also changed cables. Didn't help either.
Any help, suggestions or tips are welcome.
Rob
(Netherlands)
Verstuurd vanaf mijn Nexus 9 met Tapatalk
The message could be referring to enabling USB debugging in your Nexus and not in the App,
I don't use a Nexus so cannot offer any further advice at the moment.
Maybe this?
You're spot on Aviator!Probably Rob forgot to select the USB debugging on his tablet.
Thanks guys! I don't get the message as soon as I start the Camera mode in the app anymore. Seems this solved the problem. Still I find it particular that I have to perform this action on a factory set Nexus 9. But thanks a lot for the help.
Tomorrow I will be able tot test when connected to the Inspire.
Rob
Maass Bleche Shop
