X3 wont pan
I owned one of the early p4 that required manual gimball install with go pro,
Just got a slightly used inspire, what an improvement!
One problem is I can't get the x3 to pan.
C1 is set to switch gimbal mode. I hear a one second gear drive sound when pressing c1, but it remains in tilt. So the big question, is this a setting or is it busted?
is C1 sent in the settings to switch tilt/pan? if yes check that the camera setting is set to properly FPV will make the camera tilt like flying a plane FOLLOW will keep the camera level. so if in FPV the pan function wont work. need to be sure you are in Follow
Ok so it's buggy in free mode. However I can get it to pan with finger on screen. But can't toggle to pan. Just stays in tilt. And watching the modes, when click to tilt, it jumps from free to follow.......
What am I missing?
In follow, won't pan...
QUOTE="TruGreen, post: 192874, member: 40555"]is C1 sent in the settings to switch tilt/pan? if yes check that the camera setting is set to properly FPV will make the camera tilt like flying a plane FOLLOW will keep the camera level. so if in FPV the pan function wont work. need to be sure you are in Follow[/QUOTE]
Jenuk
