x3 yaw and roll arms
Canandaigua, New York
Hey guys, I have a question about these. They are impossible to find in the US at a reasonable price. $90 at the only place that has them. The x3 camera is not worth fixing at that price. I am in need of a couple. Is the yaw and roll arms on the x3 for the OSMO the same as the x3 for the INspire? I suspect they are.
I ordered an x3 and I am going to find out if this works. If it does I have a supplier who has a lot of the x3 for OSMO non working cameras. I will keep you guys posted on this.
You can buy an Osmo buy it now on eBay for $70 sir.
Yes it works. Depending on which arm u need u will have to remove the motor drum. Use a torch and heat it up carefully. It is epoxy. Do the same with the old drum. I use red loktite to glue it back
VefoGix
