x5 No Live Video Feed
Have been having this problem in which the DJI GO app will not display the live feed from the camera, however the camera can still capture as usual. The camera can also be controlled with the app suggesting that it is in fact connected to the device, just wont display what it sees. This problem happened after getting an Osmo with the adapter. I had updated the firmware to use on the Osmo, and when the live feed did not work, I proceeded to re-download the firmware for the Inspire 1 Pro. All Inspire 1 firmware is up to date, and this problem still persists. Is there anyone else who has experienced this? Is there a fix? And if not, is there a way to Factory Reset my DJI products to fresh boot them. Thanks!
Hi Rick,
You cann reset your lightbridge system by holding down C1, C2 and the photo trigger button on your RC. While holding these down, turn off the RC then boot it back up. Release the buttons after 3 seconds of turning on your RC.
Hope that helps,
Phil
AdolphJuq
