X5R footage, CineLight and "Local Library"
Hello,
how can I copy to or find / access the "local library" that shows up as a sidebar entry in CineLight right under the SSD? I exported some DNG footage but it doesn't show up in the "local library" nor is there an option to choose a folder location for such a local library. Could not find any related info at all.
When you add clips in cinelight that are on a HDD, they get added into Local Library. Unfortunately you only seem to be able to have 1 local library which is a fail in my opinion.
I did export DNG sequences but they wouldn't show in the library. How exactly do you add clips there?
The little + and - on the bottom left add and remove clips from external drives.
thank you very much! (It is not referred to in the manual) I overlooked this though it is rather obvious... much obliged! case closed.
anastasiyakavitko6
