X5S and 7.5mm Big Problem
RYU
Hi everyone.
My name is RYU and I'm e-mailing from JAPAN.
I'm using Inspire2 and X5S.
I bought LAOWA 7.5mm.
My X5S has licence which ProRes and RAW.
The problem is I cannot shoot RAW when using X5S with 7.5mm.
SSD is formatted safely, and using the latest firmware.
Other lenses(DJI recommend) are OK to take RAW, same X5S.
I know 7.5mm is not recommend by DJI.
I found this forum and some people saying that they can take RAW with 7.5mm.
I want to know how.Please can you help me?
And my English has a lot of mistake. Forgive me that.
Thank you.
Have you tried doing the "Hot Swap" method where you put on a recommended lens and take it off and put on the Laowa while the entire camera and drone is still on? No doubt this isn't the recommended way of switching lenses and may do harm to the gimbal, but seems to work for some.
Too bad DJI did not account for lenses that are fully manual in the settings like most M43 cameras allow for. I'd also put a request for using manual lenses in their forum too.
Dear Casey53
Thank you for your kindness reply.
I tried and it worked!!
Thank you so much. I hope DJI recommend 7.5mm officially.
Dear Casey53
Hi, This is nothing to do with your question but a realistic way to ask questions if your English is not so good, ( by the way it good :)
Use Google translate....type in your words in Japanese and convert to English then copy and paste your question...good way to see your spellings as well.
Good luck with the lens
powerdry
