X5s and DJI 15mm 1.7 with purple flare
I have a problem with flare with DJI 15mm 1.7 - pink glow/flare. The problem occurs with and without filters, and with and without a hood.
Does anyone have the same problem? It only appears when the sun is in the edge of the frame for a few moments. The problem does not appear when the sun is in the frame or near it.
I'm the only one? It's normal?
This is because yr photographing into the sun, it’s called lens flare. The purple is the sun refracting in the lens anti glare coating. A lens hood can help but if u have to photograph into the sun, then try aiming the camera down a little. I’m guessing yr using aperture priority so this is also messing up yr exposure. If u use manual settings the subject will be better exposed and the flare maybe slightly less visible.
flighta001
