- Joined
- Mar 19, 2018
- Messages
- 23
- Reaction score
- 0
- Age
- 54
I am thinking about getting X5S with Olympus 45mm but if I use the balancing ring from DJI can I still put on a ND32 filter?
Yes. I purchased the Sensei step up ring for use with the Polar Pro filters. With the Sensei and the filter the balance is very good. You may notice from many other threads, those of us with the 45mm experience drifting with this lens in use.
Thanks for sharing! Just "snatched" a last one for $9.00!
I have the same setup and no balancing issue .All I have on the front of my 45mm when I use Polar Pro filters is the Sensei ring and the Polar Pro filter.
I actually got a good balance with a Circ Pol filter alone, no sun shade, which worked great because the show I’m working on likes sun flares when I can get them. Did notice a very small drift on the bench, but a re-cal fixed it.I am thinking about getting X5S with Olympus 45mm but if I use the balancing ring from DJI can I still put on a ND32 filter?
Glad it was a help. I'm sure you'll find the balance with Polar Pros and the ring to be quite good as well.Thanks for sharing! Just "snatched" a last one for $9.00!
It have the same setup and I have no problems with it. You will be okI am thinking about getting X5S with Olympus 45mm but if I use the balancing ring from DJI can I still put on a ND32 filter?
